3D Design
3D Design
Drag and lift forces
    • pedroare
      Hello All,
      A lead is asking if Discovery is able to give as a result the moments caused by drag and lift forces or the position and magnitude of then to make the calculation manually
    • Devendra Badgujar
      Hi pedroare
      Let me check and will get back to you.
    • Devendra Badgujar
      Hi pedroare Currently, there is no option to measure Moment, although Forces can be measured using the Monitor over any face. You can use Total Force in X, Y, or Z to find the net force in that direction.
    • pedroare
      HI Devendra Badgujar , but the position of the centre of pressure  ?
    • Devendra Badgujar
      Hi pedroare
      Currently you cannot find the position of the Centre of pressure. You can calculate net force or pressure but can't calculate the Centre location for the same.
      Regards.
    • pedroare
      HI Devendra Badgujar thanks for the reply.
      Regards
Viewing 5 reply threads
  • The topic ‘Drag and lift forces’ is closed to new replies.
