August 11, 2024 at 9:57 pm
Adam Cutright
SubscriberI am writing a UDF that contains both a DPM law and DPM sources. I have two DPM injections of different particle types and at different locations, one injection is intended to represent CO2 bubbles that will dissolve in the aqueous phase which I had previously gotten working. The second injection is solid particles that are intended to grow in size based on the concentration of a corresponding species in the continuous phase. In order to distinguish between the two seperate injections I am trying to use an if-else statement shown below, with the associated "include" statements. When I try to compile using Fluent's built in compiler I get this error.
lld-link: error: undefined symbol: TP_EVAP_SECIES_INDEX
This would seem to indicate that that TP_EVAP_SPECIES_INDEX is not a recognized macro despite it being listed in the Fluent customization guide and me having the dpm_types being loaded in the UDF. If anyone understands why this is happening I would greatly appreciate the help.Â
#include "udf.h"#include "dpm.h"#include "dpm_types.h"if (TP_EVAP_SECIES_INDEX(tp) == 0) -
August 12, 2024 at 9:30 am
Forum ModeratorWhere did you find it in the manual? I've just checked the 2024R2 documentation and can't see it. Have a look at  P_INJ_ID(TP_INJECTION(tp)) Â
August 12, 2024 at 3:02 pm
Adam Cutright
SubscriberI was reading the Fluent Customization Manual and found that particular macro in 3.2.8.1. Can you point me to the section that contains P_INJ_ID(TP_INJECTION(tp))?
August 12, 2024 at 3:36 pm
Forum ModeratorWhich version of the manual are you looking at?  https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/corp/v242/en/flu_udf/flu_udf_DataAccessMacros.html is the current 3.2.8.1 with no mention of that macro. The DPM macros were updated a few releases back, so it's possible you're reading an older version of the manual. Â
August 12, 2024 at 3:50 pm
Adam Cutright
SubscriberI am reading the 2024 R2 Fluent Customization manual, when I followed the link you posted above I still see the macro I was talking about in section 3.2.8.1 which is in section 1 of the customization manual "creating and using user defined functions."
August 12, 2024 at 4:06 pm
Forum ModeratorCan you check if your code has TP_EVAP_SECIES_INDEX or TP_EVAP_SPECIES_INDEX as I read the macro from the section of code you posted?
August 12, 2024 at 5:05 pm
Adam Cutright
SubscriberI'm sorry to have taken your time, that was the issue, my UDF is functioning properly now. Thank you for your help.
August 13, 2024 at 8:41 am
Forum ModeratorNo worries. I think typos cause almost as many problems as bad coding! I'd not spotted it either.Â
5989
1307
