March 13, 2024 at 2:34 pm
desouzadacosta
SubscriberHi,
I am trying to generate the Ensight *.mpgXXX files (XXX is the particle time) for
a DPM steady flow/unsteady track . However I am getting the following message when I run 1 fluid-steady iteration :iter  continuity  x-velocity  y-velocity  z-velocity   time/iter
 2201  3.8769e-04  2.3095e-06  2.4949e-09  3.1855e-06  0:00:02   1Advancing DPM injections ....
Injecting 15 particle parcels with mass 4e-06
number tracked = 15
number tracked = 30
number tracked = 30, escaped = 1
number tracked = 29, escaped = 2
number tracked = 27, escaped = 1
number tracked = 26, escaped = 1
number tracked = 25, escaped = 1
number tracked = 24, escaped = 1
number tracked = 23, escaped = 1
number tracked = 2
number tracked = 2
number tracked = 2
number tracked = 2, escaped = 1
number tracked = 1, escaped = 1
number tracked = 0
number tracked = 0
number tracked = 0
 2202  4.9815e-04  3.9625e-06  2.8379e-09  5.2913e-06  0:00:00   0
Warning: Creating file "ens2.encas", because it does not exist.Appending to "ens2.geo"...
Done.Writing "ens2.encas"...
Done.Writing D:/aortic_arch_grabcad\.\ens2.xml...
Done.DPM Iteration ....
No history data to export for this time step.Â
In short : At the end there is no Ensight *.mpgXXX files generated
Any  clue how to solve this issue is very welcome.
The figure attached reproduces the windows of my setup.
March 15, 2024 at 2:26 pm
Prashanth
Ansys EmployeeI think you must reduce the particle time step size and number of time steps per DPM iteration, and solve many DPM iterations. You are exporting particle data only once per DPM iteration.Â
- The topic ‘DPM steady flow/unsteady tracking – no particle data export to ensight’ is closed to new replies.
