September 11, 2024 at 4:49 am
Zwernjayden
SubscriberI am trying to model atomizing impinging streams for a rocket combustion case. The DPM streams are clearly impinging, and collision+breakup occurs, but the center two jets dont seem to be impacted very much. Is there a way I can get a better transfer of momentum between particles? I tried increasing the time step, but it got to the point where it became computationally too expensive for my model. Is this a case where I should use vof to dpm transition?
September 11, 2024 at 9:43 am
Forum ModeratorAre all injections the same droplet material?Â
September 12, 2024 at 1:51 am
Zwernjayden
SubscriberNo two are multicomponent ethanol and water, the center two are Lox droplets. That shouldn't matter though right?
September 12, 2024 at 3:26 pm
Forum ModeratorIt does - read how the collision model works.Â
September 12, 2024 at 8:55 pm
Zwernjayden
SubscriberI read through manual and didn't see anything saying they had to be the same. In addition, there is another forum post I saw that determined collision is possible between unlike droplets but coalescence is not
September 13, 2024 at 12:30 pm
Forum ModeratorI'll need to recheck - I would tend to look at a collision models as likely to need other approaches. But, if a collision occurs it's a function of cell and parcel count: so if the cells are small you may find the collision maths isn't triggered.Â
September 14, 2024 at 2:27 am
Zwernjayden
SubscriberOk thank you. I know collision works because if I turn off collision, no breakup occurs at all and the streams just clip right through eachother and hit the wall. Ill try the vof-dmp transition maybe
September 16, 2024 at 1:31 pm
Forum ModeratorCheck your cell sizes, and whether the problem is repeated if all injections use the same material mixture.Â
5664
1890
1419
1304
