December 20, 2023 at 11:11 am
Adam Cwudziński
SubscriberGood mornig, I need a help with dpm model
December 26, 2023 at 1:26 pm
Kishan Konannavar
Ansys EmployeeHelloÂ
I request you please describe the issue you are facing and the specific aspect in which you need assistance. Accompanying your query with images would be very helpful.
Thank you
January 8, 2024 at 10:47 am
Adam Cwudziński
SubscriberWelcom,
Thank You very much for your reply. I considered batch reactor with water mixing by top lance via nitrogen - simple system. I used DPM model and my question is about operating density. The system not include heat transfer, constant density of water and gas. I use only wall boundary condition, with at top of reactor witch escape boundary for nitrogen. I performed simulations for operating density equal density of nitrogen or water but for both the results are not valid with resulst obtained for physical experiments of water/air system in the lab.
Thank You for help.
Regards
January 8, 2024 at 11:38 am
Forum ModeratorPlease can you post some results and what difference there is relative to the lab work?Â
January 8, 2024 at 2:51 pm
Adam Cwudziński
SubscriberWelcome,
I obtained different values of time mixing. Too large difference, by numerically mixing is too slow. In the Fluent I used species model to tracer adding. Is it possible to use DPM model without operating density? I performed many simulations via Fluent over 20 past years, but this time I can not detect errors in my Fluent settings. Could You write me suggestions to the which density value should be used in my case.Â
Regards
January 8, 2024 at 3:18 pm
Forum ModeratorOperating density may effect how the flow field behaves, but shouldn't do anything to the DPM model. As I have no idea how the flow field is behaving I can't give any guidance on settings, so please post some results so I can see what's going on.Â
January 8, 2024 at 9:06 pm
Adam Cwudziński
SubscriberDear Rob,
Thank You very much, so now I know that potential problem is elsewhere.
Regards
- The topic ‘DPM model in the Fluent’ is closed to new replies.
5729
