July 21, 2024 at 9:18 pm
Zwernjayden
SubscriberWhen I set the m_dot value of an injection, then check the injected DPM mass residual, or the outlet mass flow rate, they are significantly less than I set in the injection. Why is this?
July 22, 2024 at 10:35 am
Forum ModeratorHave they all reached the outlet? As you're injecting at kg/s are you checking kg, and if so have you account for time?Â
July 22, 2024 at 8:12 pm
Zwernjayden
SubscriberÂ
It is steady state, and when I tracked the injected mass, it started at 0, jumped up to the expected value, then dropped back to zero after a few iterations and stayed there. And yes I made sure both where in kg/s
July 23, 2024 at 8:38 am
Forum ModeratorPlease can you post an image of the particle tracks, fate report from the Console and both injection & DPM panels? Plus whatever you used to find the escaped mass.Â
July 23, 2024 at 4:17 pm
Zwernjayden
SubscriberTurns out it was because I turned on breakup which meant it needed a start and stop time, which I had just left at 0. If I want a continuous flow, do I just set stop time to 9999999?
- The topic ‘DPM injection flow rates’ is closed to new replies.
