August 19, 2020 at 12:21 pm
prashant
SubscriberHOW TO DECIDE THAT SOLUTION IS CONVERGED IN DPM EVAPORATING SPRAY CASE AS THE RESIDUALS ARE KEPT DISABLED DURING THESE SIMULATIONS
August 19, 2020 at 3:22 pmRob
Forum ModeratorWhy are residuals disabled? Use the same approach as for all other cases, mass balances (remember to take into account if you have evaporating mass), monitors and residuals.
August 25, 2020 at 2:01 pmAugust 25, 2020 at 3:02 pmDrAmine
Ansys EmployeeNot correct: You should keep the residual panel default to monitor the residuals and meanwhile terminate by residual convergence (you might probably want to monitor residuals but disable convergence by residual..)
August 26, 2020 at 3:11 amAugust 26, 2020 at 9:18 amDrAmine
Ansys EmployeeYes. If you want to disable convergence by residual under "Convergence Criterion" set it to noneAugust 29, 2020 at 3:06 amprashant
Subscriberthank you
August 31, 2020 at 12:41 pmDrAmine
Ansys EmployeeWelcome
Viewing 7 reply threads- The topic ‘DPM FLUENT’ is closed to new replies.
5674
1890
1419
