August 19, 2020 at 12:21 pm
prashant
SubscriberHOW TO DECIDE THAT SOLUTION IS CONVERGED IN DPM EVAPORATING SPRAY CASE AS THE RESIDUALS ARE KEPT DISABLED DURING THESE SIMULATIONSn -
August 19, 2020 at 3:22 pm
Forum ModeratorWhy are residuals disabled? Use the same approach as for all other cases, mass balances (remember to take into account if you have evaporating mass), monitors and residuals. n -
August 25, 2020 at 2:01 pm
August 25, 2020 at 3:02 pm
DrAmine
Ansys EmployeeNot correct: You should keep the residual panel default to monitor the residuals and meanwhile terminate by residual convergence (you might probably want to monitor residuals but disable convergence by residual..)n -
August 26, 2020 at 3:11 am
August 26, 2020 at 9:18 am
DrAmine
Ansys EmployeeYes. If you want to disable convergence by residual under Convergence Criterion set it to none,n -
August 29, 2020 at 3:06 am
prashant
Subscriberthank youn -
August 31, 2020 at 12:41 pm
DrAmine
Ansys EmployeeWelcomen
Viewing 7 reply threads
- The topic ‘DPM FLUENT’ is closed to new replies.
