DPM Drag model
    • sapkotadpak
      Hi I have spherical aerosol particles with diameters 0.5 -4 micrometer. I am confused about which drag model should I used while doing particle injection. The particle's fate is significantly altered when I switched between spherical drag law and Stokes-Cunningham drag law. Which drag law should I use?
      Have a look at the theory guide. Which one do you think you should be using? Without seeing any results I can't really comment.
  • The topic ‘DPM Drag model’ is closed to new replies.
