DPF Error – Solved but No Output
    • chonkiat.lee
      I am running a harmonic analysis with modal superposition. I can see it is solved with the green tick but frequency response output with the following error... may I know what error is it?
      DPF error - runtime error: self_call; mechanical::probe:173<-mechanical::time_scoping_chunk:171<-loop_over_workflow:205<-mechanical::apply_post:169<-mechanical::time_selector_incremental:170<-unit_convert_fc:167<-mechanical::change_cs:164<-mechanical::check_body_scoping:86<-requested result not found
    • erik.kostson
      Hi
      Can you please expalin more what you are doing - show an image if possible and describe (e.g., if you have any python code or python results, etc.).
      Thank you
      Erik
    • chonkiat.lee
      I think it seems like my computer is not good enough (RAM or Hard Disk size)
    • chonkiat.lee
      Today I have a chance to discuss with one of the ANSYS representative but we still not able to resolve the problem.It is not about the RAM or Hard Disk.
      Not quite sure about the DPF error... :(
    • erik.kostson
      Hi
      Please upgrade to 2023 R2 release.
      All the best
      Erik
Viewing 4 reply threads
  • The topic ‘DPF Error – Solved but No Output’ is closed to new replies.
