November 10, 2017 at 12:54 pm
tyw7
SubscriberMy school uses Ansys15. I would like to know how to download that specific version rather than latest version?
November 10, 2017 at 3:34 pm
Raef.Kobeissi
SubscriberThis version is not available under the Academic License, the oldest version available for download is 17.2
Regards
November 10, 2017 at 3:42 pm
tyw7
SubscriberAny advise on how to main compatibility between the two versions? I had problems when files created with the new version cannot be run on school PCs.
Or how to get that version?
November 10, 2017 at 8:21 pm
user deleted
SubscriberI had the same problem, but... Don't you use the command mode? Commands list doesn't change much from one version to another, so I think that you can just save your code and run it then on school PC.
In my university we use 11th version of it, while I have ANSYS Student 18.0 on my laptop. My code works equally good in both cases.
November 10, 2017 at 8:23 pm
tyw7
SubscriberIs there a link to a tutorial? I want to do a CFD simulation. I use Fluent.
November 10, 2017 at 8:52 pm
Raef.Kobeissi
SubscriberHello guys, usually and thats not inclusive if you generate a model on a new version you cannot open it on an older one with ANSYS but you can do the opposite, so if you generate a model using an older version you can open it using a later version. -
November 10, 2017 at 8:55 pm
tyw7
SubscriberSo if I create the work station with the older version, I can view with either edition. What if I did some work with the newer version, is it backward compatibility?
- The topic ‘Download old versions of Ansys’ is closed to new replies.
5649
1885
1404
1303
