July 28, 2021 at 4:48 pm
gopikrishnangm
SubscriberHi Lumerical
Could you let me know if the radius of curvature of the waveguide in the Lumfoundry Template "wg_strip_sbend_parameterized" can be parametrized? I couldnt find information for Curvature "C" in the required data tab of the Lumerical support website for this template (https://support.lumerical.com/hc/en-us/articles/360033721594-Waveguide-S-Bend-Parameterized-Lumfoundry-Template-)
In the .JSON file for this template there is an option for Curvature.
July 29, 2021 at 5:11 pmGWANG
Ansys EmployeeHi gopikrishnangm
Thank you for the post. These numbers I believe can be modified by users in the JSON file, and based on the geometry definition of the s-bend WGD, you can also change the parameter "jog" and "x_length" and so on to tune the curvature of it.
August 5, 2021 at 7:01 pmgopikrishnangm
SubscriberHi GWANG
Thank you for the answer!
Gopi
Viewing 2 reply threads- The topic ‘Doubt regarding Lumfoundry Template “wg_strip_sbend_parameterized”’ is closed to new replies.
5799
