July 4, 2024 at 1:03 pmmanisha kSubscriber
i wanted to know the values of Cd and Cl of the airfoil, the reports in the solution is created is the value of the cl and cd the value found in the report when given compute or is it found in the result section. if it is in result where to find it and how to check the values?
July 4, 2024 at 1:54 pmRobForum Moderator
As they're coefficients you need to check you're using the correct reference values. There are NACA tutorials/references on Learning and in the solver Help for further information.
- The topic ‘doubt regarding ansys analysis on an airfoil’ is closed to new replies.
Ansys Innovation Space
- acces to path ‘session_files’ is denied error
- Error: Result file is incomplete or corrupt. It cannot be read.
- ANSYS 2024 R2 Student License Manager Error
- Error: An error occurred when post processor attempted to load a specific result
- 설치 과정에 문제가 있습니다.
- critical error during installation of 24 R2 version
- JavaScript Runtime Error in AQWA Pre on Windows 11 (Version 24H2)
- Ansys MAxwell student data e4xport
- unexpected license problem; exiting. hit return to exit.
- No FlexNet Publisher (FNP) license found for feature HPC Parallel.
543
523
225
209
