TAGGED: #fluent-#cfd-#ansys, #heat_exchanger, fluent-mesh
March 31, 2024 at 5:47 am
Ashen Perera
SubscriberHi,Â
I am Ashen and i am doing a CFD modelling of a shell and tube heat exchanger. The model assumes the tube surfaces to be at a fixed temperature of 450C and the shell inlet to be at 300C. However , at the point of contact among the tube and the baffle the temperature doesnt remain at 450C as i have not fixated the baffle temperature at 450C should i be fixating the baffle temperature to 450C . I have attached images of my problem.
March 31, 2024 at 5:50 am
March 31, 2024 at 5:54 am
April 2, 2024 at 3:05 pm
Forum ModeratorRemember you're seeing the fluid temperature, so that may not be as warm as the wall temperature.Â
- The topic ‘Doubt about heat exchanger solution’ is closed to new replies.
1565
1386
1242
