May 10, 2022 at 12:55 pm
mem1chael
SubscriberHello everyone! I am doing my course work at the university and I have to do one auxiliary thing using Ansys, Steady-State Thermal toolbox. I have to solve the following task:
May 11, 2022 at 4:10 ammrife
Ansys Employeethere are several ways to solve this. Do you know APDL? If not create a Excel sheet with X & Y locations that cover the extent of the heat generating region. Maybe in a half unit increment. Or what ever seems appropriate to capture the equation. Then the third column is the value of that Q function. Save it as a CSV file and use External Data to read in the file. Set the columns to be X, Y and Heat Generation. Then on the WB Project page link the external data to the setup cell of the analysis. This will give an Imported Load item in the analysis. Scope it to the body and map the data to the mesh.
Search the Help for "External Data" and read up on that component system.
mike
Viewing 1 reply thread- The topic ‘Don’t know how to define internal heat generation function as a function of coordinates x, y’ is closed to new replies.
6745
1324
1087
