Ansys Products
Ansys Products
Don’t have ‘analysis systems’ after installation
    • Sukesh
      Dear Support people,
      I have downloaded and installed ANSYSACADEMICSTUDENT_2019R2_WINX64.
      Initially it gave licence error and I posted it here. Someone suggested me to renew the license. Tried that and that error is sorted out. But, got the following screen where I could not see analysis systems.
      Kindly suggest.
    • tsiriaks
      Hi Sukesh,
      What are the outputs of the following commands from the CMD Prompt
      “%AWP_ROOT194%..Shared FilesLicensingwinx64ansysli_util” -checkout aa_t_i
      “%AWP_ROOT194%..Shared FilesLicensingwinx64ansysli_util” -checkout ANS_SOLVER
      Thanks,
      Win
    • Sukesh
      Thank you for the reply.
      I have tried running the above in CMD and for both I got, The system cannot find the path specified  as output.
    • tsiriaks
      Please post the screenshots of them. Did you include the quotation mark at the front ? Make sure you include all of them.
      Thanks,
      Win
    • Sukesh
    • tsiriaks
      That's odd. Are you sure you installed 2019 R2 ?
      What is the output of
      set
      from your CMD Prompt ?
      Thanks,
      Win
    • Sukesh
    • tsiriaks
      It only shows 19.1 in your environment variables. Can you confirm if you tried installing 2019 R2 ?
      In the meantime, for 19.1, you can try these commands
      “%AWP_ROOT191%..Shared FilesLicensingwinx64ansysli_util” -checkout aa_t_i
      “%AWP_ROOT191%..Shared FilesLicensingwinx64ansysli_util” -checkout ANS_SOLVER
    • Sukesh
      Thank you!
      Yeah. I have installed 19.1, it was showing license error. In the earlier thread, People suggested to change the license file. Hence, copied a student.lic from latest version.
      Now, the above commands I have run on CMD the screenshot is below
    • tsiriaks
      Ok, this looks good.
      What was the installation package name that you used to install 19.1 ?
      Also, go to here C:Program FilesANSYS IncANSYS Student  , and see if you have install.err file in here. If so, post the content of it. If not, post the content of install.log
      Thanks,
      Win
    • Sukesh
      I dont have install.eerr file in the folder mentioned.
      install.log file contents are as mentioned below.
      Start Installation: Sun May 19 19:07:08 2019
      Revision: Release 19.1
      Platform specifics:
          Windows
      Username of Installer: LAPTOP-LQLC8OTDsukes
      User Has Administrator Privileges
      C:UserssukesAppDataLocalTempans_install_tmp14144instcore.exe -usetempdir C:UserssukesAppDataLocalTempans_install_tmp14144 -launchdir C:Ansys -admin
      Initial mount directory:
          C:Ansys
      Installation Directory:
      Windows x64
                Chemkin
                Forte
    • tsiriaks
      This does not seem like a full install.log. Could you post the entire content ?
      You may have to reinstall the software.
      Thanks,
      Win
    • Sukesh
      Thank you for your support and help.
      i have uninstalled 19.1 and installed ANSYSACADEMICSTUDENT_2019R2_WINX64. Its perfectly working.
      Thanks again
    • tsiriaks
      That's great ! Thank you for the update.
      Could you mark the thread as 'resolved' ('Is Solution') , so we know that this has been addressed ?
      Thanks,
      Win
Viewing 13 reply threads
  • The topic ‘Don’t have ‘analysis systems’ after installation’ is closed to new replies.
