July 13, 2023 at 6:54 pm
Vasanth
SubscriberI am simulating flow past bluff body. I have created a flow domain(1) and a bluff body. To capture vortex shed from body, I need finer mesh near bluff body and so i created another small domain (2). I did boolean to subtract the bluff body from two domains created. Now the second domain(2) is considered by fluent as 'wall-solid'. I am able to run the simulation and get results for sphere but I am not sure what I am doing is correct or not.
July 14, 2023 at 8:47 am
Hemant Gurav
Bbp_moderatorYes, your approach is correct. Please refer to the following course, where similar conditions are used, and in particular, check the mesh lesson.Â
CFD Simulation of an FSAE Car | Ansys Innovation Courses
July 17, 2023 at 12:03 pm
Vasanth
SubscriberThanks. I will check the video.
July 14, 2023 at 10:44 am
Forum ModeratorDomain 2 should be bounded by interior: I assume you used Share Topology?Â
July 17, 2023 at 12:05 pm
Vasanth
SubscriberI did not explicitly give a shared topology option. I will go back and see geometry and mesh again. Thanks for your response.Â
July 17, 2023 at 12:10 pm
Forum ModeratorJust to clarify. If domain 2 is a body of influence it doesn't need to be linked to the main geometry, if it's been subtracted/split then it does with share topology. The videos/course should cover this.Â
July 18, 2023 at 10:11 am
Vasanth
SubscriberReally helpful- I was trying shared topology yesterday but it did not show any shared region. I am using domain 2 as body of influence for finer mesh. Thanks for your reply.Â
- The topic ‘Domain inside a domain for finer mesh’ is closed to new replies.
5934
1306
