September 18, 2023 at 6:26 am
hone zifu
SubscriberCurrently, water falls from the entrance to the rotating surface and the flow of water is observed. The model is divided into two areas, the upper layer is 1.96mm thick and the lower layer is 0.04mm thick fluid area.
The first picture shows the ratio of water to air in the bottom layer. Currently, there is only air.
The second picture shows the interface between two fluid regions.
Does it have anything to do with the mesh being too fine?
September 20, 2023 at 5:46 pm
Prashanth
Ansys EmployeeHello, the mechanism you are trying to model is not clear. Can you elaborate, a schematic maybe?
September 20, 2023 at 6:18 pm
hone zifu
SubscriberThe overall model is as shown below. Because it is not a simple plane, I cannot use sweeping in the mesh analysis, so I divided the model into two parts, the upper thickness is 3mm and the lower thickness is 0.04mm. Use sharing to merge the two models together.
The mesh analysis uses a sweeping method to increase the thickness of the upper and lower blocks, but in the subsequent fluent flow, the liquid flows downward from the upper inlet and stops at the junction of the two models.
September 20, 2023 at 6:22 pm
September 21, 2023 at 9:22 am
Prashanth
Ansys EmployeeLooking at the mesh, the cell size jump is massive between the two zones and the aspect ratio looks to be very high. You can work on getting a well resolved mesh with similar sizes.
September 21, 2023 at 2:10 pm
hone zifu
SubscriberSo my liquid cannot flow down from the green part to the gray part because of the grid, because the fluent grid is at 0.4
September 21, 2023 at 6:07 pm
hone zifu
SubscriberWill such a mesh prevent the liquid from flowing?
September 22, 2023 at 4:58 pm
Prashanth
Ansys EmployeeYes, massive cell jumps won't be helping with tracking the VOF interface. Will recommend adding biasing and keeping the mesh resolution consistent.
September 26, 2023 at 7:59 am
- The topic ‘Doing water flow analysis, water flow does not reach the bottom’ is closed to new replies.
6199
