July 6, 2023 at 3:22 pm
javat33489
SubscriberHi all. Does the Johnson-Holmquist model not work in the Ls-Dyne Workbench?
I did sandstone cutting from the WB base, this is what happened:
Then I put in a Johnson-Holmquist material snippet (I also put in a SECTION and PART snippet to specify what material to use for the part, I created the snippet in the GEOMETRY - INSIDE MODEL section):
but the calculation stops with an error, but there is no error text:
July 7, 2023 at 12:30 pm
Ram Gopisetti
Ansys EmployeehiÂ
do you have any refernce to your work ?
do you have any formal /guided training in LSDYNA in general ? and specific to paticel methods? , if not i suggest you first get the training started.
how can you run 16 cores dispite the licenses you hold?
JH and JH-2 will run in lsdyna wb if executed properly !
 SECTION and PART snippet will not be taken under the GEOMETRY, you need to use the opton in the LSDYNA -PRE tab.Â
cheers, RamÂ
July 18, 2023 at 9:04 am
javat33489
Subscriber>>SECTION and PART snippet will not be taken under the GEOMETRY, you need to use the opton in the LSDYNA -PRE tab.Â
Sir SECTION and PART is of course used in LSDYNA -PRE tab. But I have another question, where to put the snippet with the material? Here I wrote:
if you put a snippet with material there, then it will be written to a k-file. if you only put it in the LS Dyna PRE, then the workbench will not see it. How to do it right?
thanks, so you need to clarify where to correctly insert the snippet with the material and how to do it correctly and continue the calculations with a finer mesh of particles. Looking forward to your tips and advice! Thank you.
- The topic ‘Does the Johnson-Holmquist model not work in the Ls-Dyne Workbench?’ is closed to new replies.
5799
