December 25, 2023 at 3:36 am
csZY
SubscriberHello, sir.
I am now using a dynamic mesh to simulate the settlement of objects (only affected by gravity and fluid viscosity), using a 6DoF model. I use UDF. Do I need to add buoyancy to the 6DoF UDF? Or just check the gravity in general?
My object only moves in the z-direction, and is initially subject to no other forces except gravity and the force exerted on it by the fluid. Will the 6DoF model automatically calculate buoyancy and other forces?
Thanks
January 2, 2024 at 9:21 am
Forum ModeratorIt'll get worked out using the 6DOF mass relative to the surrounding fluids, and gravity. I'm not sure of the exact mechanics but check the examples in Help as we usually demonstrate the function with a lifeboat launch or things falling off aeroplanes.Â
January 4, 2024 at 9:51 am
farzad pour
Subscriber -
January 4, 2024 at 9:52 am
farzad pour
SubscriberCould you solve the problem?Â
January 4, 2024 at 10:05 am
Forum ModeratorWhat problem?Â
January 4, 2024 at 10:11 am
farzad pour
SubscriberI mean "csZY".
 want to simulate free falling of a disk in the Fluent, but I can't. My literature review shows that free falling of a fully submerged body hasn't done by ANSYS-FLUENT but some papers have done it by STAR-CCM+!I hope, finally I will do by FLUENT!Â
January 4, 2024 at 10:47 am
Forum ModeratorWe've been doing it in Fluent since v6.x so about 21 years: look in the Fluent Help examples.Â
January 5, 2024 at 3:31 am
farzad pour
Subscriber@Rob
Despite searching a lot, I couldn't find any documents related to particles/bodies that are fully submerged in water or other fluids with high viscosity and density.
Could you please introduce any documents that are related to simulation of free falling of a fully submerged body in the water?Â
Best regards.
January 5, 2024 at 10:21 am
Forum ModeratorClick on Help in Fluent, and there's a lifeboat launch video. Similarly Tutorial 14 covers 6DOF. Remember that buoyancy is merely the result of the object and surround fluid density being different - so a drop tank falling though air is negatively buoyant, but may well float (buoyant) in water and is modelled in the same way in both cases.Â
- The topic ‘Does the 6DoF model in Fluent consider buoyancy?’ is closed to new replies.
- affinity not set
- Continuing SAG Mill Simulation with New Particle Batch in Rocky
4527
1494
1386
1209
