Does Nonlinear Mesh Adaptivity in WB support ANISO material by command snippet?
June 3, 2024 at 8:59 pm
wancheng gao
SubscriberHi all, May I ask whether in WB 2022 R2 the Nonlinear mesh adaptivity supports anisotropic material defined by command snippet?
I read the ANSYS help that only the following materials are not supported for Nonlinear adaptive remeshing.Â
When I run a model, the program was terminated with an error message stating that:Element 455645, which is part of the new mesh generated during rezoning, is associated with material 98, which has material defined by TB, ANIS, with material table number 1 and type 5.  This material    is not supported by rezoning.  Checking discontinues.Â
Could anyone give a hint on this?
Thank you in advance!
Eason
July 12, 2024 at 4:09 pm
Ashish Khemka
Forum ModeratorHi,
Is your query answered? I see it being marked as answered. Please comment.
Ashish Khemka
July 17, 2024 at 4:00 am
Asitang Lahurikar
Ansys EmployeeHi,
The error message indicates that the Nonlinear Mesh Adaptivity (NLAD) feature is not compatible with anisotropic materials. Ansys Help for 2022 R2 version discusses some materials that are not compatible with NLAD; however, you can refer the most recent documentation for more details on material models that are compatible with NLAD - 2.3. Nonlinear Mesh Adaptivity Requirements and Limitations
Hope this helps!
Asitang Lahurikar
- The topic ‘Does Nonlinear Mesh Adaptivity in WB support ANISO material by command snippet?’ is closed to new replies.
5754
