Does it possible to fix the desire number on colormap option in fluent contour ?
    • Jamessmp23
      I have a simulation results like this, and I want it to be the same scale on colormap.
      Any suggestion ?
      *PS. I found the discussion post on 2013, they said it was a limitation on fluent colormap.
      Best regard,
      James
      You mean fix the range or the number of colour bands? The former can be done in the various Results panels (contours, vectors) just turn off one of the settings. If you want to adjust the bands that's also on the results panel. The colours can be altered via View -> Colormap.
    • Keyur Kanade
    • Jamessmp23
      Okay. I mean according to the picture, the top red color it should be 1.12e+00 for all of the similar simulations and each colors on the scale should represent the same numbers for all of similar simulations . Can it be adjust ?
      I tried to work with the colormap(changing type, precision, colormap size, log scale) but it doesn't solve my problem.
      regards,
      James
    • Keyur Kanade
      in contours dialogue box, please deselect auto range. then you can give inputs for min and max.
      if this helps you, please mark this post as 'is solution' to help others on forum.
    • Jamessmp23
      Thank you for the answer simple and clear.
Viewing 5 reply threads
  • The topic ‘Does it possible to fix the desire number on colormap option in fluent contour ?’ is closed to new replies.
