August 15, 2020 at 5:32 am
ahmedshafie
SubscriberI wanna konw if choosing between first upwinding , or quick , can affect accuracy : error with respect to validated data , i know it affects convergence in residuals .
August 17, 2020 at 1:07 pmAmine Ben Hadj Ali
Ansys EmployeeYes they affect the quality of the results especially if you are running on coarse grid.
Good reference by the way: https://www.grc.nasa.gov/WWW/wind/valid/tutorial/errors.html
August 17, 2020 at 1:17 pmahmedshafie
Subscriberthanks for your generous answer , if i did mesh independent test so it wont affect quality right ?
August 17, 2020 at 1:57 pmAmine Ben Hadj Ali
Ansys EmployeeShould not be affected anymore. Actually you need to try to provide a high order solution on an independent grid.
August 17, 2020 at 2:27 pmahmedshafie
Subscriberthanks for your great help
August 17, 2020 at 2:38 pmAmine Ben Hadj Ali
Ansys EmployeeWelcome
Viewing 5 reply threads- The topic ‘Does interpolation numercial schemes method affect convergence only not accuracy?’ is closed to new replies.
Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
Top Contributors-
4362
1494
1375
1198
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
