October 24, 2021 at 8:48 pm
yu.zhu14
SubscriberHello everyone,
After running a simulation in CFX 19.2, the following error message appeared:
Parallel run: Received message from slave
 Slave partition :    7
 Slave routine  : CFXMSG
 Master location : FINPAR
 Message label  : 001100288
 Message follows below - :Â
 | ERROR #001100288 has occurred in subroutine CFXMSG.        |
 | Message:     Â
 | The following message handling error occurred:Â
 | Write                           Â
 | Hostname: ce-yz17014
 | Port number:  56389       Â
 | Messages will now be handled using a less robust method,  with a greater risk of parallel deadlocks. Â
 | Note: Ensure that the hostname shown above can be resolved from all hosts used for the run.
This seems to have no influence on the results, however, when I tried to run another simulation using the results from this one as the initial condition, I encountered another error:
 Slave partition :    7
 Slave routine  : ErrAction
 Master location : Message Handler
 Message label  : 001100279
 | ERROR #001100279 has occurred in subroutine ErrAction.       |
 | Message:                              |
 | Stopped in routine FPX: C_FPX_HANDLER  Â
Any ideas on what happened here?
October 27, 2021 at 10:34 pmSurya Deb
Ansys EmployeeHello,
Is this happening for this specific model or can you replicate this with any CFX model?
Regards SD
November 1, 2021 at 3:33 pmyu.zhu14
SubscriberHi SD Thanks for your reply and sorry about my late replying.
This error never shows again after I deleted a previous version of CFX V15.0 so I think it might be something related to compatibility.
In regarding your question, it was happening for all models that I tried to run.
Yours Yu
Viewing 2 reply threads- The topic ‘Does anyone encounter this error in CFX? ‘ERROR #001100288 has occurred in subroutine CFXMSG.’’ is closed to new replies.
