December 4, 2024 at 9:29 am
tuanhoanglai123
Bbp_participantHi all, i wonder if Ansys Modal includes object's selfweight in analysis or not.
I'm modelling a pipe section (using 3D Solid element) to determine its frequencies respective to the first 4 mode shapes. However, I was afraid that Modal does not count on this aspect, especially weight in vertical direction, so I insert "Standard Earth Gravity" via a Static Strutural module, along with fixed support at 1 pipe end as well as displacement constraint at the other end (only free for pipe axial direction). Then, put the results from Static Strutural module into Modal module as pre-stress. However, the program keeps sending error message "During the multiframe restart process, neither the .RDB file nor the .Rnnn files were found. Â Both files are required to perform the multiframe restart for the linear perturbation analysis. Â You must use the RESCONTROL,LINEAR command in the prior base analysis. Â The ANTYPE, ,RESTART command is ignored."
So I assumed inserting "Standard Earth Gravity" via a Static Strutural module is incorrect and not necessary. Please advise my confusion. Thank you all in advance!
December 4, 2024 at 9:44 am
ErKo
Ansys EmployeeÂ
Hi
See our course for pre-stress modal analysis (what it is, .. and how to set it up).
Watch through the video in detail .
https://www.youtube.com/watch?v=XyCZVHl8QKg
All the best
Erik
December 4, 2024 at 9:55 am
tuanhoanglai123
Bbp_participantHi Erik,
Thank for your reply.
What i confuse is that my pipe is laid in vertical direction, which probably results in different responses when compared to horizontally laying. Is there any way I can express this idea in the program?
December 4, 2024 at 10:12 am
ErKo
Ansys EmployeeAgain go through that course in detail and you will understand what loads and resulting stress/displ. do in a pre-stress modal analysis.
All the best
Erik
5694
1891
1419
