April 18, 2025 at 3:47 pm
Yahia
SubscriberHi everyone;
Could you please share with the documentation file of LSTC.H3_50TH_STANDING.100630_BETA. Model (if available). I have the FEM but I need the documentation file to be able to known the injury criteria, like jntforc ...The model only has node number, so it may take time to extract data without the docuemtation.
April 21, 2025 at 5:15 pm
igandiko
Ansys EmployeePlease check documents under occupant modeling workshop available here: https://ftp.lstc.com/user/lstc-dummies/. Please check with your ls-dyna license provided for login credentials. Note that the dummy model mentioned in the tutorial may be different but you can refer the documents for general post-processing guidance.
(or) You can also check the join locations in LSPP (see *constrained_joint_<> cards) and check respective output in jntforc database.
2979
970
857
755
599
