July 17, 2024 at 2:39 am
xin zhang
SubscriberI am looking at far-field radiation from a dipole source, using the top half of a box-type far-field projection monitor with a base, and I want to know: 1. Is far-field filtering required when using a box monitor? 2. How to set filtering parameters (because I found that the electric field at the edge of the display is very large, should it be filtered directly to 0) 3. In the case of many displays, the filtering parameters at this time may vary, whichever is preferred
July 19, 2024 at 7:56 pm
Guilin Sun
Ansys EmployeeThe farfield filter is used to smooth the fields in the monitor in order to not use very large simulation/monitor size. But the farfield accuracy might be compromised.
If you are using box monitors, there is no need to use such filter, since it uses
farfieldexact
method to get the farfield from all related monitors.
July 22, 2024 at 6:42 am
xin zhang
SubscriberThank you very much for your reply. Can I understand this way: If the electric field is cut off to zero inside or at the edge of the monitor by using a larger monitor, then the far-field filter function can be unnecessary. If I want to observe the far-field radiation pattern distribution of particles on the substrate (possibly SPPs waves), is a box monitor the best choice? Are there requirements for the location of the box monitor for the dipole source and distance from other structures? Hope to get your reply, thank you very much!
July 25, 2024 at 2:48 am
xin zhang
SubscriberCan you help me? It's really important to me. Thank you so much
July 25, 2024 at 4:31 pm
Guilin Sun
Ansys EmployeeYes, the filter is to smooth the monitor data and make sure the intensity at the monitor edges is small enough. Thus if the monitor (and simulation region) is large enough you do not need to use it.
For particle on substrate, you can try to use 5 box monitors in analysis group, or use large FDTD and monitor spans to pick up all the scattering.
https://optics.ansys.com/hc/en-us/articles/4403945613843-Polar-plot-of-scattered-field-with-particle-on-substrate
If box monitors are in lossless material, the distance does not matter.
July 27, 2024 at 2:28 am
xin zhang
SubscriberThank you again for your reply, this information is very useful to me, thank you very much!
- The topic ‘Do I need to use “farfieldfilter” in far field projections from a box of monitor’ is closed to new replies.
5799
