March 6, 2024 at 8:16 am
Tomas Black
SubscriberDear all,
If we have already set the surface bonded contact between two parts, do I still need to set the solid interaction between them? I find that whether or not the solid interaction is set, the results obtained from the calculations can be different.
Thanks,
Tomas -
March 6, 2024 at 2:47 pm
Armin
Ansys EmployeeHi Tomas,
If you have already defined your contact pairs, it is good practice to disable the Body Interactions.Â
You can check the knowledge material below for more information:/knowledge/forums/topic/what-is-the-difference-between-body-interactions-and-contact-regions-in-an-explicit-dynamics-system/
March 6, 2024 at 3:11 pm
Tomas Black
SubscriberThank you Armin, I will try as suggested
- The topic ‘Do I need to set both surface contact and body interaction in workbench LS-DYNA?’ is closed to new replies.
1890
1419
1304
