August 7, 2024 at 6:17 pm
javat33489
SubscriberHello everyone. I work on a 24/48 core PC with an AMD EPYC core.
When I do a calculation without using DMP specifying the number of cores, the solution to the problem on 16 cores is faster than on 20 or 24. And if I set 8 cores, then there is no difference in time at all.
When I enable DMP and specify the cores when starting the calculation, I get an error:Why? How to use all cores?
August 8, 2024 at 10:50 pm
Reno Genest
Ansys EmployeeHello Javat,
SMP does not scale well beyond about 8 cores. So, you should not see a speedup beyond 8 cores and you may actually see speed degradation with more cores.
When you activate DMP, the MPP version of LS-DYNA is used (as opposed to SMP). MPP will scale well beyond 8 cores and it is the solver to use to utilize all your cores.
With MPP LS-DYNA you get mesXXXX files. For example, if you run on 24 cores, you will get mes0000 - mes0023 files in the working directory and the error message can be found in one or many mesXXXX files. So, you have to look at all the mesXXXX to find a meaningful error message. You can also use the following webapp to save time and extract error messages from mesXXXX automatically:
https://nagasairam112-check-dyna-errors-error-dyna-check-rq20je.streamlit.app/
Hopefully, you will extract a proper error message that will help you troubleshoot the problem.
You will find more information on SMP and MPP LS-DYNA here:
Microsoft PowerPoint - mpp_201305 (lstc.com)
Let me know how it goes.
Reno.
August 13, 2024 at 4:57 pm
August 20, 2024 at 4:41 pm
javat33489
SubscriberHelp please
August 20, 2024 at 4:50 pm
Reno Genest
Ansys EmployeeHello javat,
You get the problem only when running MPP LS-DYNA? SMP runs fine?
Have you tried a different version of LS-DYNA?
Reno.
August 20, 2024 at 6:06 pm
javat33489
SubscriberYes, SMP works well.
I use the new 2024 version.
August 20, 2024 at 6:16 pm
Reno Genest
Ansys EmployeeTry with a different version of LS-DYNA (R15.0.2 is the latest version):
LS-DYNA (user=user) Download Page (lstc.com)
username: user
password: computer
Also, try LS-RUN to run LS-DYNA MPP.Â
LS-Run 1.0 tutorial (youtube.com)
Reno.
5649
1885
1404
1303
