Diverging Results with density based solver
    • ae22b001
      Hello all, The inlet of my geometry has a supersonic nozzle. I am trying to simulate flow through it in steady state initially and then later in
      unsteady conditions.
      With the density based solver I was able to get a decent steady state solution altho the residuals weren't perfect. When I started to run the transient solution , my results start diverging near the wall, which I think is caused by high accept ratio cells near the wall/inflation layers. Without the inflation layers, it is working.
      However, when I use the pressure based solver  I am able to get really good results with inflation layers as well. I want to recreate the results using density based solver as Mach number in my flow exceeds 3.
      Please let me know how to fix this issue.
      I will attach pictures
    • ae22b001
      Mesh
      Solver settings for steady state simulation
      I have also tried turning warped face gradient correction off but it still diverges in the transient simualtion.
      Courant no - 5
      when I start the transient sim, after some iterations:
      1. So how do I reduce residuals in steady state, right now its oscialllting somewhere between 1e-3 and 1e-4
        2. How do I prevent this from diverging as shown above in transient sim?
        Thanks
    • ae22b001
      Hello, any help would be greatly appreciated. Thanks
    • ae22b001
      Hi, any ideas on how to solve this problem? It works well with pressure based solver, but does not with the density based solver
      • ae22b001
        Hello, any help would be greatly appreciated. thanks
    • ae22b001
      Any ideas? Thanks
Viewing 4 reply threads
  • The topic ‘Diverging Results with density based solver’ is closed to new replies.
