May 24, 2024 at 8:08 am
jihoon beak
SubscriberHello!
I want to implement a simulation of deformation and separation when heat is applied to a spiral multi-layer structure.
I am running the simulation with contact debonding conditions.
However, as the simulation progresses, errors continue to occur. I have tried increasing the number of meshes or applying a very small temperature change, but errors still persist.Â
Does anyone know how to solve this problem?
May 29, 2024 at 9:27 am
Ashish Khemka
Forum ModeratorHi,
What are the number of substeps? Why the update stiffness is turned to Never? The mesh seems to be fine, try running the model with a coarse mesh first to debug the issue. Did you check the contact status before solving? Please see if these comments help.
Ashish Khemka
- The topic ‘Divergence Issues Due to Structural Changes in Multi-layer Systems’ is closed to new replies.
