July 31, 2020 at 5:55 pm
VivekKamble
Ansys EmployeeHow is distortion different from attenuation?
July 31, 2020 at 5:56 pm
CB
Ansys EmployeeHello Vivek,
Attenuation can be defined as the loss in signal power when it is propagating through a communication medium, whereas, distortion is the change in the signal properties which are not uniform. Distortion is of many types - amplitude distortion, phase distortion etc. Both are dependent on the properties of the communication medium. Distortion occurs if multiple components of the signal undergo different attenuation thereby waveform of the signal is changed. Distortion occurs if the medium properties are not uniform.
- The topic ‘Distortion and attenuation’ is closed to new replies.
Ansys Innovation Space
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
1414
1231
1118
1015
