September 11, 2024 at 1:23 pm
kayla-anne.e.jack
SubscriberHello,
The mechanical test below shows deformation in the X-Axis for my model. How can I get the distance between the min and max points before and after the laod is applies? I intend to use the values to calcuate diametrical strain at the region (change in diameter/original diameter).
And is there anyways to automate the process? ie. can I create a graph compareing the force applied to the system to the diametrical strain?
September 11, 2024 at 1:27 pm
ErKo
Ansys EmployeeHi
This post might be useful:
https://innovationspace.ansys.com/forum/forums/topic/measure-distance-between-two-ends-or-edges/
All the bestErik
September 11, 2024 at 1:51 pm
kayla-anne.e.jack
SubscriberHello, thank you for your reply. Unfortunatly that post doesn't explain how to find the distance between the points before the load is applied. Is it possible to measure these points before running the simulation? I have created nodes at the min and max points, however I don't know how to measure the distance between the nodes.
September 11, 2024 at 1:56 pm
ErKo
Ansys EmployeeWe can use selection information and select these 2 nodes - that will give the distance between them before the deformation.
Search/google for that: selection information and ansys
5934
1307
