May 9, 2024 at 5:28 pm
buksa
SubscriberHello. I have a question. Is it possible to model the dissolution of a salt crystal using Fluent? I want the walls of my model to be covered with salt crystals. When high humidity air flows, I want the crystal to absorb water from the air and dissolve, changing its mass.
Regards, Dominik
May 10, 2024 at 9:17 am
Forum ModeratorYes. However, unless you are going to code up moving mesh on the walls to mimic the mass loss you may not see what you want. Starting point for the above might be surface reactions or Eulerian Wall Film. Note, neither approach is simple and may require User Defined Functions to be written.Â
- The topic ‘Dissolving a salt crystal’ is closed to new replies.
