LS Dyna
LS Dyna
Display Fringe Component Results during Animations
    • jeff.burgess
      Within LS-PrePost, whenever I animate results, the fringe results do not update continuously while the animation is running. Stopping the animation at any time step and reselecting the desired fringe result will display it, but restarting the animation again erases the fringe plot and the animation resumes without any fringe data presented.
      Is there a setting within LSPP to display fringe results during animations?
    • Andreas Koutras
      Hello Jeff,
      Thanks for reporting that. Indeed this may occur, if I understand the issue correctly. There is no other setting to avoid this I think. You may try with a newer LSPP version to see if the behavior is different.
      Thanks.
    • Armin
      Hi Jeff,
      You can select "Fringe Range" and then choose between Dynamic and Static options for the fringe. Please see the image below:
    • jeff.burgess
      Thank you for the feedback. Indeed this seems to be a bug with LSPP v 4.8.29. I have upgraded to v4.10 and this issue has been corrected. Thank you.
  • The topic ‘Display Fringe Component Results during Animations’ is closed to new replies.
