November 1, 2018 at 4:10 pm
Sam Fares
SubscriberHello,
Is there a way to display component or solid name that is in the tree on the member depicted in sketch area? or when you click on solid it displays the name of the solid without looking at the tree.Â
SamÂ
November 1, 2018 at 5:32 pm
Sandeep Medikonda
Ansys EmployeeYou can always annotate.
What application are you using? Design Modeler? SpaceClaim?
Sandeep -
November 1, 2018 at 5:44 pm
November 1, 2018 at 6:06 pm
Sam Fares
SubscriberThank you Sandeep!
What you suggested is what i have been doing. i was trying to avoid writing notes.
In the tree, is there a way after i rename the solid, the component will have the same name? Now i am renaming the component and renaming the solid. i want to minimize my renaming work . Â
Regards
Sam
November 1, 2018 at 11:21 pm
Sandeep Medikonda
Ansys EmployeeYeah, I think it has to be manually redone sam. I am not aware of a simpler way other than scripting may be.
Sandeep -
November 2, 2018 at 6:12 am
Keyur Kanade
Ansys EmployeeYou can display name.Â
When you select any body in model tree, it is highlighted in graphics.Â
When you select any body in graphics, you can use right click and use Locate in Structure Tree
Hope this helps.Â
Keyur
November 2, 2018 at 1:27 pm
Sam Fares
SubscriberYes that is what i have been doing. Thank you both Sandeep and Keyur!
Sam Fares
- The topic ‘Display component or solid name on the member within the structure sketch’ is closed to new replies.
4863
1587
1386
1242
