February 27, 2024 at 3:07 pm
Maryam Tabbakhh
SubscriberHi,
I have a question regarding the animation of the results. I have a block that is gravity initialize in the water and then is subjected to the earthquake loads. The deformation under gravity initialized is much bigger than under dynamic loads. So, when I apply the scale factor to see the movement of the block better, it jumps out of the screen. Do you have any recommendation for me to show it nicely? I mean apply SF for the movement of dynamic loads and we skip the scale factor for gravity initialization? ThanksÂ
February 29, 2024 at 3:24 pm
Ushnish Basu
Ansys EmployeeCurrently, we plot modified coordinates as follows:
x=x0+dsf*(x-x0)
where x0 is the initial coordinates.
I have asked the LSPP team to make an enhancement, where we apply the scale factor to a user-specified state k, i.e.
x=xk+dsf*(x-xk)
Potentially, we can also set dsf=1 before state k, and to the user-specified value afterward.
I cannot say at present if and when this new feature might become available
February 29, 2024 at 4:14 pm
Maryam Tabbakhh
SubscriberThank you very much for your response.Â
- The topic ‘displacement scale factor’ is closed to new replies.
3647
1313
1142
1075
1013
