Displacement/cyclic loading shows zero deflection.
    • Sneha E S
      When i applied displscement/cyclic loading for an RCC beam its showing zero deflection, first i provided fixed support at both end then one end fixed other pinned still shows zero deflection. the displacement was applied over two small section over the face which was supposed to act as a load applying area then all over the face still shows zero deflection. please help.
    • ashish.khemka
      Can you share the snapshots of faces where fixed support, displacement and force are applied?
      Ashish Khemka
      • Sneha E S
        I have not applied any force here, displacement is provided by a tabular data with value ±1.9517 which i obtained by applying force all over the upper face and solving it for total deformation
    • Sneha E S
      Now my model is missing, it is seen nowhere on the screen but when i click on the total deformation a blue colour keeps on popping on the screen as it goes from minimum to maximum value. I tried closing and opening the app again but still no change. A message shown is"One or more objects may have lost some scoping attachments during the geometry update. You can identify these tree objects by filtering the tree using the Scoping option set to Partial." but when scoping option is set to partial again nothing is present.
    • Sneha E S
      Please help!!!! My model is missing. Thw warining shows "One or more objects may have lost some scoping attachments during the geometry update. You can identify these tree objects by filtering the tree using the Scoping option set to Partial.". But i tried rectifying it still no use.
    • ashish.khemka
      Can you try importing the geometry in other analysis system and see if the model reappears?
      Ashish Khemka
    • Rahul Kumbhar
      Hi Sneha, Right click in Window and use 'Show All'. Use 'Zoom to Fit' option.
Viewing 5 reply threads
  • The topic ‘Displacement/cyclic loading shows zero deflection.’ is closed to new replies.
