May 12, 2023 at 10:59 pm
user deleted
SubscriberHello
I am using the DPM model to simulate a particles injection from a nozzle. The nozzle has a spray pattern in the form of a solid cone with a spray angle of 30°.
Can you please tell me how to set the spray angle and solid cone shape for the spray pattern?
Spraying is carried out through a nozzle with a diameter of 0.3 mm into a closed container. I set the inlet as a circle with a diameter of 0.3mm. But I don't have the slightest understanding of how to make the shape of a spray torch - a solid cone and the right angle of the cone.Â
Attached a photo of the model below.
Thank you in advance for your help, this is part of my thesis, I'am absolutely beginner in Ansys -
May 12, 2023 at 11:48 pm
May 12, 2023 at 11:54 pm
May 15, 2023 at 10:21 am
Forum ModeratorPlease can you post the DPM injection panel? I want to see what you've set.Â
May 16, 2023 at 2:05 am
user deleted
SubscriberHello RobÂThank you for agreeing to help meÂAttached below is a photo of the injection panel. I can't figure out how to set solid cone spraying. As I understand it, the speed in x,y,z allows you to set only one velocity vector, and not a set of vectors.ÂI will also add the information that I am modeling the spraying of solid microparticles from the inlet, a stream of CO2 also comes out of the inlet. I use Fluid Flow (Fluent). (perhaps in this software package it is impossible to set the shape of a solid particle spray torch and you need to use another package?)
May 16, 2023 at 10:31 am
Forum ModeratorOK, solid cone is a separate injection type: look under the "injection type" option. Remember injections don't need to be linked to surfaces.Â
May 17, 2023 at 1:33 am
user deleted
SubscriberHello RobÂI am very grateful to you, your advice helped me.ÂÂI was able to set the spray torch I needed for the particles. But I had a question how to make the gas flow out of the inlet also in the form of a solid cone. I attach my settings to the inlet panel (I have changed almost nothing from the standard ones).ÂÂ -
May 17, 2023 at 10:29 am
Forum ModeratorDo you want gas or DPM particles (bubbles)? For gas you'd need to use the Velocity Specification and set the components.Â
May 17, 2023 at 11:49 am
user deleted
SubscriberMy model implies that solid particles and gas come out of the nozzle with a solid cone spray torch at the same time. The gas is a continuous phase, the particles are discrete.
In DPM (as I understand it) I set the speed and shape of the solid cone only for particles (a photo of the DPM panel with the parameters I selected is attached).
But, as I understand it, from the inlet with the parameters that I set, the gas flow does not come out in the form of a solid cone, but simply perpendicular to the plane (this is confirmed by the shape of the flow after I started the solver and got the results)
May 17, 2023 at 1:04 pm
Forum ModeratorThe fluid flow part would be a boundary, and you may use profiles/UDF/expressions to alter the direction. Look at the options next to Velocity Specification Method. Or you'll need to extend the domain a bit (very precise measurement) to let Fluent calculate the flow to give the cone.Â
The DPM injection then handles the solid particles (in your example).Â
May 22, 2023 at 11:03 pm
user deleted
Subscriberthank you very much, you helped me a lot, Rob
January 2, 2024 at 9:09 am
Zain Khan
Subscriberas this thread is still open, i wonder why solid cone has no parcel option
January 2, 2024 at 12:03 pm
Forum ModeratorI'm fairly sure that the number of parcel is set by the number of streams and stochastic tries unless some other models are on.Â
- The topic ‘Discrete Phase Model DPM – how to create solid cone injection’ is closed to new replies.
- affinity not set
- Continuing SAG Mill Simulation with New Particle Batch in Rocky
4512
1494
1386
1209
