December 6, 2023 at 8:07 am
jwkim23
SubscriberIs there a way to monitor the run time of flow analysis? If so, what do you do?
December 6, 2023 at 8:21 am
Devendra Badgujar
Forum ModeratorHello Ji Won,Â
Option to monitor run time is not possible yet. Let me check if there is any other way to get those.Â
Devendra
December 6, 2023 at 8:40 am
jwkim23
SubscriberAll right. I'll be waiting
December 6, 2023 at 9:29 am
Devendra Badgujar
Forum ModeratorÂ
Hello Ji Won,Â
You can find the solve time from the Application logs from here C:\Users\user name\AppData\Local\Temp\Discovery\latest session directory\Logs\
Thanks,
DevendraÂ
December 6, 2023 at 10:31 am
jwkim23
SubscriberFirst of all, thank you for being able to get information about run time using the method you mentioned. However, in the picture above, a log file is created when the livegx solver is used, but a log file is not created when the livegx solver is not used. So how do I check the run time when the livegx solver is not used?
- The topic ‘Discovery run time’ is closed to new replies.
5834
