3D Design
3D Design
Discovery License – Add on
    • smjang
      Hello
      Please inquire about the discovery license.
      As far as I know, if you only purchase Ansys Discovery, it will only be interpreted in the Explore stage.
      And I know that I need to purchase an additional function (Add-on) for the refine stage analysis and Mechanical/Fluent linkage.
      Currently, our customers are using Ansys products (Mechanical/Fluent). Do these people need to purchase additional functions (Add-on) to link Mechanical/Fluent after performing analysis in Ansys Discovery?
      I have confirmed that the button linked to Mechanical/Fluent is not activated when only Ansys Discovery is purchased.
      Please give me a quick reply on this.
    • Devendra Badgujar
      Hi  smjang
      Discovery Modelling license will enable only Discovery Model mode and a Discovery Simulation license will enable Discovery Explore mode.
      Whereas, for Refine mode, customer needs to have a minimum of Mech/ CFD Pro license for Structural/Fluid simulation respectively.
      To activate the Mechanical/Fluent Transfer, Discovery needs to be a Floating license and not Subscription.
      Also, please ensure that the licenses are on the same server and minimum Boundary conditions are defined before attempting to transfer.
      Regards.
      • smjang
        Devendra Badgujar
        Then, if the customer has a Pro Level license of Mechanical / Fluent, will the Discovery Simulation license be transferred to the Refine stage and the Workbench?
        And is it possible even if the Pro Level license of Mechanical / Fluent is different from the Discovery version? (ex, Discovery 2021r2 / Mechanical 2018)
    • Devendra Badgujar
      Hi smjang
      Yes the customer can transfer to the Refine stage and the Workbench if they have a Pro Level License of Mechanical/Fluent.
      But the old version of this Pro license will not work, they will need to update this Pro level license version of Mechanical/Fluent to 2021 R2.
      Regards.
      • smjang
        Devendra Badgujar Thank you. I guess I'll have to purchase an additional Pro Level license that matches the Discovery version. thank you.
      • smjang
        Devendra Badgujar
        I have one more question to ask.
        Is the license of Mechanical/Flunet Pro Level of Discovery Add-ON the same as the Pro license belonging to Pro/Premium/Enterprise of Ansys Mechanical license?
        If it is the same, if a customer purchases Discovery Add-ON, is it possible to run Mechanical alone after installing the Mechanical file?
    • Devendra Badgujar
      Hi smjang
      Since this is business/license specific question, I will suggest you to please contact through email to your Ansys Channel Partner Manager. He can internally connect you to the Discovery product team.
      Regards.
      • smjang
        Devendra Badgujar Thank you for answer. Your answer has been very helpful. As you said, more details will be provided through Ansys Channel Partner Manage. thank you.
  • The topic ‘Discovery License – Add on’ is closed to new replies.
