Ansys Products
Ansys Products
Discovery Issue with Wind Simulation Going through Solid Objects
    • nehendrickson
      I imported a car model from Autodesk Fusion via a STEP file and when I run a air simulation, the wind goes through the tires rather than around them.
    • Harshvardhan
      This issue might occur if the tyres are "Suppressed for Physics". Kindly check for the same and re-run the simulation.
      I hope this helps.
      Harshvardhan
      Ansys Help
      Ansys Learning Forum (Rules & Guidelines)
