February 20, 2023 at 2:25 am
Roberto
SubscriberHelloÂ
1) if I take some measurements and export them in dxf they are not exported, is it possible as an improvement to have them exported?
2)Â If I deactivate the tangent lines and export( dxf,dwg) the geometry the lines keep them, this is an error
Regards
​ 🛈​ This post originally contained file attachments which have been removed in compliance with the updated ​ Ansys Learning Forum Terms & Conditions​ -
February 20, 2023 at 5:37 am
Atharv Joshi
Forum ModeratorHi Roberto ,
Let me check and get back to you.
Thanks & Regards
February 22, 2023 at 3:50 am
Atharv Joshi
I have raised an enhancement request for exporting the dimensions given on an annotation plane in 3d view. I will let you know once I hear back.
Second one is not an error, by turning off Tangent from the display you are just hiding the tangent lines being displayed and they still exist in the model , hence will be exported in the drawing.
Thanks and Regards
February 23, 2023 at 2:50 am
Roberto
SubscriberHello Atharv Joshi
there should be a function where by exporting to dxf the tangent lines are deactivated , is it possible to make a request ?
If you think of a complex drawing with many parts if you were to export in 2d with all tangent lines it would be difficult to understand
Regards
March 17, 2023 at 6:43 am
Roberto
I am waiting for your reply
Regards
March 20, 2023 at 12:32 am
Atharv Joshi
Forum ModeratorHello Roberto ,
Sorry for the delay. I have already raised an enhancement request for the exporting dxf with tangent lines deactivated.
Will let you know once I have any update on this.Â
Thanks and Regards
- The topic ‘Discovery information’ is closed to new replies.
5899
1306
