May 9, 2025 at 9:36 am
SDB Engineering
SubscriberHi,
Is it possible to make the option to use as an external CAD also available to Discovery?
See screenshot below.
The reason is that now for Discovery CAD files, Mechanical makes a local copy of the CAD file, renames it to some generic SYS-... filename and points to that local copy. The link to the original CAD file is broken.
That is unwanted behavior. In case of Spaceclaim and the option "use a sexternal CAD" it keeps referencing to the original CAD file without making a local copy.Ot is there another way to keep linking to the original CAD file instead of that Mechanical makes a local copy and renames it to SYS-something?
Thanks in advance!
May 12, 2025 at 5:51 am
Charudatta Bandgar
SubscriberHello,
This is not currently possible. The Sys file will be created for every session with Discovery.
Thanks for the suggestion, I will take this to the development and get some insight.
Charudatta B
6395
