October 23, 2024 at 7:03 pm
eaometz
SubscriberHello,
I am encountering an issue where Discovery 2024 R2 is crashing quite quickly. I attached a video of the symptoms I am encountering. ÂHere's what I have done:
-Installed Ansys & license manager using ZIP packages from the websiteÂ
-Uninstalled after encountering this issue-Installed again using the automated installer-Updated gpu drivers
-tried importing using .sldprt, parasolid, and stl-entirely remadeÂ-Disabled Dedicated graphics in device managerÂ-Reinstalled windows using windows update utility (reinstalles fresh windows install without losing files)None of these fixed the issueÂSide note, the samples in discovery work fine. Â
What should I do to fix crashing?ÂÂCrashing video:
https://youtu.be/QCtfWYVUyBk -
October 28, 2024 at 12:57 pm
George Karnos
Ansys EmployeeDoes this only happen with one model that you import?
Or does it happen with every part that you import?
