September 20, 2024 at 9:20 pm
September 23, 2024 at 6:06 pm
Guilin Sun
Ansys EmployeeIt is correct, since now you are plotting the total field. If you only plot the tangential field components it will be continuous. In the normal direction it is the displacement field that is continuous.
September 23, 2024 at 8:31 pm
Minming He
SubscriberThank you for you reply. I still have one question: according to this disagram, can I say that the power is leaking into the substrate?
September 23, 2024 at 9:45 pm
September 25, 2024 at 4:13 pm
Guilin Sun
Ansys EmployeeEz is not continuous since it is normal to the boundary;
When there is field inside the substrate, it does not necessarily mean leakage, of course depending on your definition of leakage. Usually when the substrate is lossy we can say leakage. You can calculate the loss inside the sub strate.
Viewing 4 reply threads
1307
