February 21, 2023 at 10:59 am
Arthike Kandasamy
SubscriberCurrently, I am engaged in setting up an overset mesh. Nevertheless, the surface mesh seems to deteriorate near the edges. The setup I am using is as follows:ÂÂFor the mesh colored in dark blue the area enclosed within it is designated as a void. This mesh makes contact with the red mesh at its bottom through a circular contact region. The light blue mesh depicts the overset boundary. The blue mesh slides over the red mesh thorugh the fluid region.ÂÂÂÂThe blue wall and the red wall have an overlapping region. However, during the initialization of the overset connection, orphan cells arise near the edge. Notably, these cells emerge between the red and blue wall, and not adjacent to an overset boundary. As we progress towards the overset boundary away from the edge, the faces of the dark blue mesh and the red mesh are appropriately aligned. Could somebody explain why this is happening? Sometimes it does work when I increase or decrease the surface mesh of the blue wall. I even used the following command: (rpsetvar 'overset/cut/thin-cut-nlayer). Sometimes it does work with this command.ÂÂ -
February 24, 2023 at 1:16 pm
Federico
Ansys EmployeeHello Arthike,
could you please re-upload your images? The attachments to your last post appear to be broken and cannot be displayed.
- The topic ‘Disappearing grid during oversetmeshing’ is closed to new replies.
