November 22, 2024 at 8:17 am
Stephan
SubscriberHello,
I'm experiencing issues with rendering performance in HFSS (2024R2) especially when I import complex models or when my models get more complex.
Fortunately, sometimes the application automatically disables the "Accurate Transparency Rendering" which significantly accelerates the rendering performance.
I'm wondering if it is possible to manually disable this setting in Ansys HFSS.
Any help would be appreciated.
November 29, 2024 at 10:29 am
Mrinmoy Bharadwaj
Ansys EmployeeYou can set the default transparency by going to Tools>Options>General Options>3D Modeler>Display>Rendering
December 27, 2024 at 2:52 pm
Stephan
SubscriberSorry but this is not the answer I was looking for. My problem is that I'm experiencing low FPS problems when I import a complex STEP file. After playing around for a while program prompts a message about disabling "Accurate Transparency Rendering" which fixes this problem and improves FPS dramatically. I'm looking for ways to disable this option manually whenever I need to.
6159
