TAGGED: ansys-mechanical, bolt-pretension, constraints, loadsteps
December 1, 2020 at 12:46 pm
Ladderdale
SubscriberHi. I have a model consisting of several parts held together by bolts. Firctional contact is applied between the bodies. The bolts will be pre tensionsed in 3 stages. Due to this configuration the model is not very stable and I have issues getting it to converge. nWhat i would like to do is to add a zero displacement to some of the parts i the first 2 load steps, so that the bolt pre tensioning steps will converge. Thereafter I would like to disable the displacement before i apply the external loads. Is this possible?nYour help i appreciated. n -
December 1, 2020 at 1:04 pm
December 1, 2020 at 1:22 pm
Ladderdale
SubscriberAh, so its been hiding underneath there all the time:). I'll give that ago. Thanks for your help!n -
December 3, 2020 at 1:57 pm
- The topic ‘Disable constraints in a load step.’ is closed to new replies.
