July 6, 2023 at 10:35 pm
Tonmoy
SubscriberHi everyone!
For our simulation we were largly using the LS-PrePost to postprocess the output files. Now, we were wondering, if there is any way to save only the results (displacement, velocity and acceleration) of specific nodes in an ASCII/text file directly without the need to open lsprepost again?
Thanks in advance for your help!
- Tonmoy.
July 7, 2023 at 12:09 pm
Ram Gopisetti
Ansys EmployeeHi,
try using the database_history_node (id, set)
in smp run it outputs nodeout which has following header with time stamp
nodal point x-disp y-disp z-disp x-vel y-vel z-vel x-accl y-accl z-accl x-coor y-coor z-coor
in mpp run it will be output in binout you can also check the elout database
cheers, ram
July 8, 2023 at 12:16 am
Jim Day
Ansys EmployeeIn addition to *DATABASE_HISTORY_NODE to choose the nodes for output, you'll need to include *DATABASE_NODOUT to specify the output time interval for the output file nodout. When you run SMP LS-DYNA, nodout is simply a text file. -
July 12, 2023 at 3:21 am
Tonmoy
SubscriberThank you, Ram and Dr. Day, for your helpful responses and wonderful clarifications. Our model has many components and requires a lot of computational resources, so MPP was our to go.
However, now I have another relevant question: is there any way to read and process the data from the “binout” file without using LS-PrePost or save it directly as a text file?
July 12, 2023 at 5:51 am
Tonmoy
SubscriberAll right, I've found that another subscriber already asked that question and that solves this problem. Interested users can take a look at that: /forum/forums/topic/ls-dyna-output-extension/
Thank you again Dr. Day and Ram for you input on this issue.
- The topic ‘Directly save the response of a node using LS-PrePost’ is closed to new replies.
5964
1307
